theholybull
Ive got a problem with my 02 libby with the 3.7. I took off to take my kid to school today and there was a sudden arrival of engine knock and an immense loss of power. I was less than a mile from the house so i nursed her home. I figured the worst, blown head gasket. i checked the oil, no coolant on the oil. I checked the plugs, no coolant. I checked compression, all clyinders over 100. Switched coil packs around still runs rough. All my plugs are a little sooty except for the number 6 plug. I sprayed carb cleaner around the intake and there are no leaks. It sounds like there is something banging around in the intake, almost like the engine is back firing through the intake. I wont have a scanner to pull the codes untill later tonight so right now im at a loss. The only thing i can think of is that i lost a crank or cam sensor and its defaulted to bank injection instead of multi port, i know this happens in chevys and fords but im not sure about jeeps. Ive pretty much ruled out valve issues and a blown head gasket due to the compression tests and lack of coolant any where but in the cooling system It almost has to be a sensor, can anyone tell me whats going on here?
edit: the mechanical timing is dead on as well, so it didnt jump time and that rules out another issue.
