How To
How To: Change front driveshaft / change a driveshaft head
This is a discussion on How To: Change front driveshaft / change a driveshaft head within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
If your driveshaft boot looks like this its time to replace the head or get a new driveshaft, replacing the ...
Like Tree65Likes
Old 11-15-2010, 11:25 PM   #1 (permalink)
twack's Avatar
Send a message via AIM to twack
Default How To: Change front driveshaft / change a driveshaft head
If your driveshaft boot looks like this its time to replace the head or get a new driveshaft, replacing the head is only 1/3 the cost so why not just do that.
first step is to hit up eric at automotivepartsunlimited.com and get your new head or driveshaft
Remove the 6, 8mm bolt on each side of the drive shaft. highlighted in green
pull the transfer case side of the driveshaft up over the transfer case yoke, pull the transmission side down and under.
Here is what a front driveshaft looks like
Here is what a dead boot looks like, it was full of sand and grit
use a set of snap ring pliers to remove the retaining clip
Now paint your driveshaft so it dosnt look like total crap.......just kidding i was bored. (and yes my coffee table is rhino lined)
slid on new boot and crimp the band
fill boot side up with grease, and grease the new head
Slid on the new head and install new retaining clip
Fill top side of head with grease and insert top plate making sure its flat on all sides
toss it back in the same way and have fun. I reused the 8mm bolts that were on the jeep because the new ones had larger heads that would be a little harder for my tools to get in there.
2002 liberty sport
Front
- OME 925LDs, with 1 coil removed + 2.5 daystar spacer + rancho struts
Rear
- daystar 2.5 + bottom rear isolator + stock springs + Cheap durango shocks
Mods
- front D-rings + jet stage 2 chip + "cold air intake + 400watt inverter + 1600watt system + black mesh grill inserts + tinted tails and sidemarkers + Treadwright Guard Dogs 31s + Cragar soft 8s + JBA oldskool A-arms
twack is offline   Reply With Quote
Old 11-16-2010, 03:37 PM   #2 (permalink)
ericautopart's Avatar
Send a message via AIM to ericautopart
Thanks for the plug. Doesn't that grease stink? Looks like a good write up..can't think of anything he missed..
jrsavoie likes this.
Automotive Parts Unlimited, LLC
800-270-5224 or ericautopart@aol.com
Your source for drive shafts, bearings, axles, etc..
http://www.facebook.com/#!/pages/Aut...20413477999893
ericautopart is offline   Reply With Quote
Old 11-16-2010, 06:43 PM   #3 (permalink)
twack's Avatar
ya that grease stinks, i did it in my basement and it was interesting to say the least
2002 liberty sport
Front
Rear
Mods
Old 12-11-2010, 11:54 AM   #4 (permalink)
WOW!!! This is a great "How-To" .. and the timing couldn't have been better.
My son just blew out the head & boot off of the driveshaft. He was taking the 4WD mode off onto 2WD .. while going 120KPH .. What was he thinking?!?!?
And, the local dealers do not have any in stock.
I have heard that I can remove the driveshaft AND still be able to drive around without it. Only thing is, I won't be able to use the 4WD mode albeit, minus the noise from all those blown up pieces.
Is that true?
Thanks.
RTam is offline   Reply With Quote
Old 12-11-2010, 05:08 PM   #5 (permalink)
twack's Avatar
yup thats true just dont toss it in 4wd
2002 liberty sport
Front
Rear
Mods
Old 12-11-2010, 11:29 PM   #6 (permalink)
Thanks twack!!! Your "How-To" saved me a ton of guess-work.
I have the driveshaft removed and the KJ is back in operation (minus the 4WD option and noise).
The front head & boot is still in good condition. Curiosity got the better part of me and I removed both clips to take a peek. All I saw was a bunch of goop coming out. Looks like I will need to get new clips and goop for the front head.
However, the tail part is not so good. I will need the exact part that you have in that box (picture 2 & 3). What is that part called? It says "CV joint". I tried looking for it in automotivepartsunlimited.com. But, I could not see that part.
I have a 2005 Liberty 3.7L Rocky Mountain Ed. Does anyone know what part# that may be? And, where I can get one? Will they ship to Ontario, Canada? If not, I have an address in Buffalo, NY that I can use as a shipping address just in case.
Thanks.
73surf likes this.
Old 12-11-2010, 11:47 PM   #7 (permalink)
twack's Avatar
800-270-5224 ask for eric or ericautopart@aol.com
or hes on here to
http://www.jeepkj.com/forum/members/ericautopart.html
2002 liberty sport
Front
Rear
Mods
Old 12-17-2010, 09:59 AM   #8 (permalink)
Nooby's Avatar
it's not too hard to replace the joint, I got mine from eric a month ago or so, and it is working good, just got the first snow yesterday so got to test it out, no problems with the joint,
I would recomend geting a good snap ring plyiers, I first tried a cheap multi snap ring plyier from harbor freight, it broke and was a pain in the butt, I got a sears professional snap ring plyer
2006 Dodge Grand Caravan SXT v6 3.8L
2002 Jeep Liberty Renegade v6 3.7L
-----2000 Dodge Avenger, 1991 Eagle Talon, 1989 Dodge Dakota----
Mods
Added Evic
Added backup lights
Nooby is offline   Reply With Quote
Old 12-17-2010, 01:59 PM   #9 (permalink)
twack's Avatar
i got mine on with a cheap snap ring pliers but trust me a nice pair will make it much easier
2002 liberty sport
Front
Rear
Mods
Old 04-27-2011, 08:57 PM   #10 (permalink)
BjBnet's Avatar
gotta do mine in the next couple of weeks. Thanks for the write up. I think I'm gonna paint mine too...good idea.
*EDIT* what type of grease do I need?
'04 3.7 Columbia Edition
Goodyear Wrangler Territory 245/75
2.5" Frankenlift, 2 washers on clevis, 2 extra rear ISOs
JBA UCAs
Upgraded Interior Courtesy lights to LED
K&N Air Filter
Front Shackles
Light Bar and a bunch of other things I don't need
BjBnet is offline   Reply With Quote
