How To
HOW TO: Flush/Change Coolant
This is a discussion on HOW TO: Flush/Change Coolant within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
From the Service Manual, by request. STANDARD PROCEDURE STANDARD PROCEDURE - DRAINING COOLING SYSTEM 3.7L ENGINE WARNING: DO NOT REMOVE ...
Like Tree9Likes
Old 01-07-2005, 11:54 AM   #1 (permalink)
BluPhant's Avatar
Send a message via ICQ to BluPhant Send a message via AIM to BluPhant
Default HOW TO: Flush/Change Coolant
STANDARD PROCEDURE
WARNING: DO NOT REMOVE THE CYLINDER BLOCK DRAIN PLUGS (Fig. 5) OR LOOSEN THE RADIATOR DRAINCOCK WITH SYSTEM HOT AND UNDER PRESSURE. SERIOUS BURNS FROM COOLANT CAN OCCUR.
(1) DO NOT remove radiator cap first. With engine cold, raise vehicle on a hoist and locate radiator draincock.
NOTE: Radiator draincock is located on the left/lower side of radiator facing to rear of vehicle.
(2) Attach one end of a hose to the draincock. Put the other end into a clean container. Open draincock and drain coolant from radiator. This will empty the coolant reserve/overflow tank. The coolant does not have to be removed from the tank unless the system is being refilled with a fresh mixture. When tank is empty, remove radiator cap and continue draining cooling system.
STANDARD PROCEDURE - REFILLING
(1) Tighten the radiator draincock and the cylinder block drain plug(s) (if removed).
CAUTION: Failure to purge air from the cooling system can result in an overheating condition and severe engine damage.
(2) .Fill system using a 50/50 mixture of ethyleneglycol antifreeze and low mineral content water.Fill pressure bottle to service line.and install cap.
NOTE: The engine cooling system will push any remaining air into the coolant bottle within about an hour of normal driving. As a result, a drop in coolant level in the pressure bottle may occur. If the engine cooling system overheats and pushes coolant into the overflow side of the coolant bottle, this coolant will be sucked back into the cooling system ONLY IF THE PRESSURE CAP IS LEFT ON THE BOTTLE. Removing the pressure cap breaks the vacuum path between the two bottle sections and the coolant will not return to cooling system.
(3) With heater control unit in the HEAT position, operate engine with pressure bottle cap in place.
(4) Add coolant to pressure bottle as necessary. Only add coolant to the pressure bottle when the engine is cold. Coolant level in a warm engine will be higher due to thermal expansion. NOTE: The coolant bottle has two chambers. Coolant will normally only be in the outboard (larger) of the two. The inboard chamber is only to recover coolant in the event of an overheat or after a recent service fill. The inboard chamber should normally be empty. If there is coolant in the overflow side of the coolant bottle (after several warm/cold cycles of the engine) and coolant level is above cold full when cold, disconnect the end of the overflow hose at the fill neck and lower it into a clean container. Allow coolant to drain into the container until emptied. Reconnect overflow hose to fill neck.
STANDARD PROCEDURE - COOLING SYSTEM - REVERSE FLUSHING
CAUTION: The cooling system normally operates at 97-to-110 kPa (14-to -16 psi) pressure. Exceeding this pressure may damage the radiator or hoses.
Reverse flushing of the cooling system is the forcing of water through the cooling system. This is done using air pressure in the opposite direction of normal coolant flow. It is usually only necessary with very dirty systems with evidence of partial plugging.
CHEMICAL CLEANING
If visual inspection indicates the formation of sludge or scaly deposits, use a radiator cleaner (Mopar Radiator Kleen or equivalent) before flushing. This will soften scale and other deposits and aid the flushing operation. CAUTION: Be sure instructions on the container are followed.
REVERSE FLUSHING RADIATOR
Disconnect the radiator hoses from the radiator fittings. Attach a section of radiator hose to the radiator bottom outlet fitting and insert the flushing gun. Connect a water supply hose and air supply hose to the flushing gun. CAUTION: The cooling system normally operates at 97-to-110 kPa (14- to-16 psi) pressure. Exceeding this pressure may damage the radiator or hoses. Allow the radiator to fill with water. When radiator is filled, apply air in short blasts allowing radiator to refill between blasts. Continue this reverse flushing until clean water flows out through rear of radiator cooling tube passages. For more information, refer to operating instructions supplied with flushing equipment. Have radiator cleaned more extensively by a radiator repair shop.
REVERSE FLUSHING ENGINE
Drain the cooling system (Refer to 7 - COOLING - STANDARD PROCEDURE). Remove the thermostat housing and thermostat. Install the thermostat housing. Disconnect the radiator upper hose from the radiator and attach the flushing gun to the hose. Disconnect the radiator lower hose from the water pump. Attach a lead away hose to the water pump inlet fitting.
CAUTION: Be sure that the heater control valve is closed (heat off). This is done to prevent coolant flow with scale and other deposits from entering the heater core.Connect the water supply hose and air supply hose to the flushing gun. Allow the engine to fill with water. When the engine is filled, apply air in short blasts, allowing the system to fill between air blasts. Continue until clean water flows through the lead away hose. For more information, refer to operating instructions supplied with flushing equipment. Remove the lead away hose, flushing gun, water supply hose and air supply hose. Remove the thermostat housing (Refer to 7 - COOLING/ENGINE/ENGINE COOLANT THERMOSTAT - REMOVAL).
Install the thermostat and housing with a replacement gasket (Refer to 7 COOLING/ENGINE/ENGINE COOLANT THERMOSTAT - INSTALLATION). Connect the radiator hoses. Refill the cooling system with the correct antifreeze/water mixture (Refer to 7 - COOLING - STANDARD PROCEDURE).
2oo2 Liberty Sport [Patriot Blue]
Leather Seats/Alpine iDA-X001 HU/SC-C1 Sirius Tuner/Wheel Locks/Foglites/nüvi 200W GPS
EVIC from 2ooo GC/EVS II Security (Sentry Key)/Under-Dash Courtesy Lights/Hunter 4x4 steps
Rear Flipper Glass Pad/Trail Rated Badge/Custom tin
t
2oo7 Commander Limited [Black]
V8 4.7l Flex Fuel, Remote Start, GPS, Saddle Brown Leather, REC GPS, VES, Sirius, Tow Package
"No one can make you feel inferior without your consent."
Eleanor Roosevelt, 'This Is My Story,' 1937
BluPhant is offline   Reply With Quote
Old 01-07-2005, 03:27 PM   #2 (permalink)
yoda13's Avatar
Great how-to Blu =D>
For over a thousand generations, the Jedi Knights were the guardians of peace and justice in the Old Republic. Before the dark times, before the Empire.
LIVESTRONG
-Put this in your profile if you know someone who is fighting, has survived, or died of cancer
JeepKJ Country #025
2007 White Jeep Wrangler X 2-door
yoda13 is offline   Reply With Quote
Old 01-05-2009, 11:00 AM   #3 (permalink)
Mangate's Avatar
Send a message via MSN to Mangate
How do you reach the cylinder drain plugs, from below or from above?
2002 Liberty Sport
2003 Liberty Ltd.
Mangate is offline   Reply With Quote
Old 01-12-2009, 08:59 AM   #4 (permalink)
jeepkj02's Avatar
Step 1- remove engine
Step 2- drain cylinder block
Step 3- reinstall engine
....LOL!!
2002 Jeep KJ Sport 4x4
DOB: 5/17/01 ~ Mileage: 84,xxx
Current Mods:
OME MD Lift w/Ranchos, ARB Bumper, Firestone A/T on Cragars, Optima Red Top, Flowmaster Super 44, Hella 500's
jeepkj02 is offline   Reply With Quote
Old 01-17-2009, 05:47 AM   #5 (permalink)
How do you purge air from the cooling system? Has anyone had this problem when following the instructions above?
Thanks
Thermos
thermos is offline   Reply With Quote
Old 01-17-2009, 12:25 PM   #6 (permalink)
jeepkj02's Avatar
After you finished draining out the old coolant (and replacing hoses/thermstat) refill the system. Leave the radiator cap off. Turn the heater on full and start the engine. Bubbles will start to come out of the coolant tank, top if off when needed, when bubbling stops cap off the tank turn heat back to normal/off and take for a spin. Next morning, before starting, check the tank and top off if needed.
Current Mods:
Old 01-18-2009, 07:05 AM   #7 (permalink)
Thanks for the reply.
Thermos
Old 05-14-2009, 04:41 PM   #8 (permalink)
I followed the instructions. but now when i'm filling up only got about 8 qts in before it's "full". The owners manuel and shop manual say 13 qt capacity. I pretty sure I got all the old stuff out and did a rinse too until it ran clear.
Should i let it run on high heat for a bit then refill as it's running or let it cool down?
Thanks,
Mike
Signcutter21 is offline   Reply With Quote
Old 09-26-2009, 10:50 PM   #9 (permalink)
I am about two weeks away from doing this
Two more questions I have are:-
1) It is essential that the engine block drain is removed (I would hate to strip the tread etc). The way I normally do it on other cars is cycle a few fills of water and then fill with coolant/distilled water. Is that ok?
2) I take it that the radiator cap is the yellow cap on the coolant bottle.
Thanks in advance
Thermos
Old 09-29-2009, 07:52 PM   #10 (permalink)
Mangate's Avatar
Thanks in advance
Thermos
1) I wouldn't worry about striping the thread, you can't even see those screws let alone get them out. Unless you do as Jeepkj02 says and remove the engine first. Then you'll have easy access to repair the striped thread. Seriously, you would probably have to remove the exhaust where it joins the manifold on the drivers side, and the starter motor just to get to the screw. The passenger side you might just be able to do by feel. They need an allen key by the way, can't remember the size, maybe 1/4 or 3/16. I flushed the system with water then refilled with coolant till it ran out the same colour as going in, but I wasted probably half a gallon doing this.
2) Yes
2002 Liberty Sport
2003 Liberty Ltd.
