Register to remove these ads.
How To
HOW TO: replace blower motor assembly
This is a discussion on HOW TO: replace blower motor assembly within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
Register to remove these ads. It's free! If you find you're blower motor has gone out and you need to ...
Like Tree3Likes
Old 04-25-2008, 02:54 AM   #1 (permalink)
Corwyyn's Avatar
Default HOW TO: replace blower motor assembly
If you find you're blower motor has gone out and you need to replace it please DO NOT pay the dealership to do it. With the proper tools and a bit of mechanical knowledge this is about a fifteen minute job.
What you will need:
1) replacement blower assembly
2) phillips head screwdriver
3) flashlight or other light source
4) mirror (not necessary but it makes the swap a LOT easier)
To start off, you'll need to locate the two phillips head screws on the insulation panel under the glove box. Remove these and lower the panel out, then place it out of the way.
Now that the panel is removed you'll be able to see the blower motor hanging down from the housing:
Locate the wiring connector on the side of motor. Press the red locking clip forward as indicated, then press down on the back end of the connector and pull it off the motor:
This is the part where the mirror comes in handy. You'll need to find the locking tab on the motor (the part that has the paint mark on it) and pull it down enough to allow the motor assembly to rotate as shown:
Once the assembly has rotated enough it will start to drop out; carefully tilt the blower motor assembly down and remove it from the housing.
Now you're ready to install the new assembly which is basically the reverse of what you've just done. The only thing you'll need to watch for is to make sure you get the tabs aligned properly so that the blower motor will rotate into position. Once it's installed hook up the wiring connector, turn the ignition to 'ON' and verify that the blower works on all settings. Replace the insulation panel and the two screws, then pick up all the tools and sit back.
That's it! If you've done everything properly you'll once again have a nice stream of air coming from the vents and be a very happy Jeep owner
profdlp and QuickSilver like this.
Kevin
'03 Flame Red Liberty
"A stick of dynamite to blow out the side of the tomb, scoop the bones aside, you grab the Amulet and you run"
I. Jones
American Journal of Archaeology
1932
Corwyyn is offline   Reply With Quote
Old 04-25-2008, 05:11 AM   #2 (permalink)
JIMMY JEEP's Avatar
Nice write up with informative direction arrows Corwyyn thanks.
2004, KJ 2.8 CRD LIMITED
CHROME GRILLE
A BAR ,SIDE BARS
17" 2005 SPEC ALLOYS
16"'s WITH GOODYEAR ATR'S
CLEAR FRONT INDICATORS
STAINLESS NUMBERPLATE SURROUND
STARTECH CLEAR SIDE REPEATERS
STARTECH HALF LEATHER HALF ALUMINIUM STEERING WHEEL.
JIMMY JEEP is offline   Reply With Quote
Old 04-25-2008, 02:01 PM   #3 (permalink)
BluPhant's Avatar
Send a message via ICQ to BluPhant Send a message via AIM to BluPhant
...and if you have a sport, pick up a courtesy light & install it @ the same time
LOL.. yeah, you're handy with the photoshop there, dood.
-Blu
2oo2 Liberty Sport [Patriot Blue]
Leather Seats/Alpine iDA-X001 HU/SC-C1 Sirius Tuner/Wheel Locks/Foglites/nüvi 200W GPS
EVIC from 2ooo GC/EVS II Security (Sentry Key)/Under-Dash Courtesy Lights/Hunter 4x4 steps
Rear Flipper Glass Pad/Trail Rated Badge/Custom tin
t
2oo7 Commander Limited [Black]
V8 4.7l Flex Fuel, Remote Start, GPS, Saddle Brown Leather, REC GPS, VES, Sirius, Tow Package
"No one can make you feel inferior without your consent."
Eleanor Roosevelt, 'This Is My Story,' 1937
BluPhant is offline   Reply With Quote
Old 04-25-2008, 05:35 PM   #4 (permalink)
AZKJ's Avatar
Thanks Kevin... a very good how-to.
- '06 Jeep KJ Sport... w/some stuff
- '08 Jeep JK X... w/more stuff
AZKJ is offline   Reply With Quote
Old 06-13-2008, 11:03 AM   #5 (permalink)
mightybeet's Avatar
Send a message via AIM to mightybeet
great thread!! my fan 1st and 2nd settings have just died on me.
mightybeet is offline   Reply With Quote
Old 06-15-2008, 02:13 AM   #6 (permalink)
Arizona KJ Carlos's Avatar
Kevin, great job on this write up...pretty easy to follow
Arizona KJ Carlos
2003 Jeep Liberty Limited Ed
1.5" Daystar Lift kit
Jeep MOAB Wheels
Goodyear MTR's
Yakima Bike Rack
Find out more at www.carlossamano.com
Arizona KJ Carlos is offline   Reply With Quote
Old 11-26-2008, 10:48 AM   #7 (permalink)
Default loosing #1 & #2 on fan switch
folks,
any diagnosis tips? 3 and 4 setting are fine but any easy way to determine if it is the switch, resistor or fan itself? I am trying not to fix by process of elimination anymore
krusty is offline   Reply With Quote
Old 11-26-2008, 03:47 PM   #8 (permalink)
Corwyyn's Avatar
Originally Posted by krusty View Post
folks,
Actually you've already done your process of elimination. If you have speed three and four on your fan this tells you two things: 1) the fan still works, 2) the resistor block is going out. This is bad because you have to replace the resistor block, but good because you can buy 5 or 6 of thoses for the cost of one blower assembly. While switches can fail it tends to be an uncommon condition.
Kevin
I. Jones
1932
Old 02-22-2010, 12:27 PM   #9 (permalink)
Default lost fan settings 1, 2, and 3; but 4 works just fine
So, if I'm reading correctly... this is an issue with the fan's resistor block?? Any tips on how to fix/replace that (where is it?)?
bobbyd is offline   Reply With Quote
Old 02-22-2010, 12:54 PM   #10 (permalink)
ridenby's Avatar
Gold Supporter
There is a good How to on the resistor block.
02/3.7/45RFE/231/212,000+miles
Frankenlifted
31-11.50-15 LTB's
Aussie locker
Thrush Glasspac
JBA 4.5 A-arms
12,500lbs china winch
custom paint
ridenby is offline   Reply With Quote
