BluPhant
As with any electric/electronic project involving ANY car, please remember to disconnect your negative battery terminal prior to starting.
A quick look in the service manual gives us instructions about how to replace lights in your dash. They are incandescnet lights and should be available at your Jeep dealer.
The p/n for the lights:04839738AA Cluster has 9 of these bulbs in total.
CLUSTER BEZEL REMOVAL
(1) Remove the drives side trim bezels.
(1A) Remove the A pillar cover
(2) Remove the instrument panel top cover.(lift the left side only to acces cluster screw)
(3) Remove the seven screws and remove the cluster bezel.
There is a piece of plastic covering this hole for some reason, take of fusebox lid and door seal to take it out / fit it back the right way.
CLUSTER REMOVAL
(1) Disconnect and isolate the battery negative cable.
(2) Remove the cluster bezel from the instrument panel.
(BP: See above)
(3) Remove the four screws that secure the instrument cluster to the instrument panel (Fig. 3).
(4) Pull the instrument cluster rearward far enough to access and disconnect the instrument panel wire harness connector for the cluster from the cluster connector receptacle.
(5) Remove the instrument cluster from the instrument panel.
CLUSTER BULB
This procedure applies to each of the incandescent cluster illumination lamp and bulb holder units.
(2) Remove the instrument cluster from the instrument panel.
(BP: See above)
(3) Turn the bulb holder counterclockwise about sixty degrees on the cluster electronic circuit board (Fig. 4).
To reassemble, follow directions in reverse!
-Blu
Pics and some extra info added - Tonycrd
CLUSTER REMOVAL
(BP: See above)
CLUSTER BULB
(BP: See above)
-Blu
