How can I tell if I have the limited slip differential?
csukoh78
Nunya
Im about to do a differential fluid change, when it occured to me...how do I know if I need to buy the additive for the limited slip differential?
thecause17
North Huntingdon, PA
Should be a tag on the rear diff somewhere stating the rear end designation. If not you could go to a dealer and get them to print out a build sheet, and on there it will tell you what it has.
csukoh78
Nunya
hahaha no, I found the label, but went and got the build sheet anyway, good idea to find its history. Sorry for the confusion!
SoDakJeep
is there anyother way to tell i cant find a tag and i see some sticker but its like almost completely off so I cant tell????
rhy
bay area
looks like this, mine has it, it says trac lock driver side back axle
myjeepwalks
Easy way to tell is to jack up the back end, put it in neutral and spin the rear tires. If they both spin the same way trac-lok. If one spins one way and the other spins the oppisite; open diff.
pr0zak8
Quebec city
the main diffrence between a trac-lok and an open carrier is the clutches inside of it ... the way it works is simple ! your wheels spin tthe oil heat between the cluches , they stick together and both wheels start spining ! but in normal driving , a trak=loc operats the same way as an open carrier axle ! so if you jack it up on a lift you ll have to spin your wheel real real fast if you want to check it its limited slip or not !! so either find the tag , ask at dealler ship or wait till you change your axle fluid , remove the cover and look at it !!
BNJ-KJ
Columbia, KY
I've been wondering the same question as the original post and now I know that I don't have the limited slip:(
decibelchild
canada
does a non limited slip diff axel still have the sticker? i have a green sticker on the axel but it is illegible, heres hoping, i need to find some mud this friday and find out that way hehe
