driveability
- Joined
- Jun 28, 2008
- Messages
- 16
- Reaction score
- 2
Hello,
I'm new here, my neighbor sold his 02 Liberty, 2 wheel drive, auto, Limited model to me for 1,200 dollars.
The Jeep is like new, however has a major engine issue. I took a look at it and found # 2 cylinder had no compression, upon removing the valve cover I found the rocker off to the side and out of place. It looks like the intake valve is not returning to the up-right/closed position. I haven't moved lower in the engine as yet. The engine cranks and will run, HST its won't go over 20 mph.. Theres no odd noise or any kind of harsh metal to metal sounds etc.
I think the seat fell out and is jammed up against the #2 valve..
The car did get hot 3 months ago, the radiator and water pump were replaced, it ran perfect until it was restarted after a short stop for fast food.
Everything happened just like that...
What do you think ?
What do you think ?
