HOW TO: Run power for basket roof lights
Bennett
Active Member
Green Bay
Some people have been asking me how I ran the power to my basket, here's how.
First, I ran the wires inside of the bar to make it look clean and simple.
It's also nice you can ground the lights inside the bar, so you only need to run one wire down into the engine bay.
and then it runs down the side of the window. I actually ran two power wires one down both sides of the front window, so that each wire + only runs two lights of the four lights. I did this since then I could use a smaller guage wire, and I put each side on their own relay as well.
ALSO see TRAILN's thread which came in quite handy when I ran first did the project.
http://pub21.ezboard.com/fkjjeepfrm33.showMessage?topicID=148.topic
Later,
Bennett
Bennett
Active Member
Green Bay
Yes, it gets its power directly from the battery, but is controlled by a relay.
TRAILN
Toronto, CANADA
I made mine with switch power so if I leave them on the shut off with the key. All my electrical is done this way.
Bennett
Active Member
Green Bay
Same here, my relay is connected to the accessory wire with a switch in between.
Bennett
Active Member
Green Bay
There are many places inside that can be used as accessory wires. Mainly all of my devices that are controlled with relays are just simply tapped into the cigarette lighter at the fuse panel, since it is switched power with the key.
Bennett
Corwyyn
Southeast of disorder...
kolesy
Goldsboro, NC
Hey Bennet, can you elaborate on the wiring of your lights? As how you wired them in with your accesories and such. I would love to have mine wired up and not let them be turned on when my pig ain't runnin.
HDP
USA
Does anyone have the pics for this HOW TO? I've fabricated my own rail mounted light bar and I'm trying to figure how to run wires without drilling holes in the roof...
Easy , remove screws from moulding along drivers side door, ( alongside windshield ) run wires up in behind it, reinstall
HDP
USA
Thanks, but how do I get the wires inside?
Firewall in engine bay
Sent from my SM-N910V using Tapatalk
There are a couple of places where there are rubber plugs that you can run the wires through . Drivers side near steering column
