Not true, not true, not true. If you don't have factory installed TPMS sensors in your wheels, you can't do ANYTHING except use 04 sensors with an 04 EVIC that has TPMS built into it (04-07 Sport). That is the ONLY year you can use. If you have an 05-07 that came with TPMS sensors in the wheels, meaning the LABS Tire Pressure Warning Light in the dash...tough. YOU CANNOT GET A "TPMS EVIC." There is no such thing. I know everyone with an 06 sport claims they got a TPMS EVIC because when they installed it in their car it is chiming at them about their tire pressures, but it does not have TPMS. That is bunk. All 05-07 EVICs are exactly the same minus the Homelink and base differences. So really there is only 2 options out there. Having a Limited, meaning having the TPMS sensors in your wheels WILL NOT work with an 05-07 EVIC. The EVIC no longer contains the integrated TPMS module, that is why the 04, which did, required training magnets and interfaced directly with the wheels, with no wheel well transponders. In order to have the EVIC read your tire pressures and report it, you must have gotten that $75 option added on from the factory, it required a completely different wiring and parts setup which receive those TPMS signals from the wheel wells, read the actual pressure, and then display that on the EVIC.
So back to these Sport owners installing an EVIC in their car that beeps about the pressure. It is doing that because the car it came out of had the premium pressure system and it is still configured for that. Hooking it into a Sport, which lacks the TPMS function in any capacity (warning light or Monitoring system) and the associated sensors, wheel well transponders and hardware does not reconfigure it as there is no conflicting signal being sent to it saying this car does not have the Monitoring System. Go put that EVIC into a Limited that only has the warning light and it will see the TPMS system and that it is a Warning Light only system, and reconfigure itself. Why nobody has figured this out yet, I don't know. These are the facts, flame away.
