scull20
Sorry for the crappyish pictures, only had a few more minutes till sundown after I got back from work. You'll get the idea. I used a 4'x4' sheet of 3/4" plywood from Home Depot for the bottom and walls, the Walmart replacement auto carpet, and a lot of staples as you might be able to see lol. There is also a 1"x4' wooden dowel held in by two 1" conduit clamps. The majority of staples were used for wrapping the walls of the shelf in carpet, kinda like a stitching with staples were the two ends of the carpet met. The walls are 3" high if I remember correctly, and I just eyeballed the angle of the one wall against the rear seats, set the circular saw and took the edge off. Unfortunately, all I had laying around were 2 inch drywall screws so I pre-drilled the majority of the holes. It took me in all about 6 hours to build...the carpet was the hardest and most tedious part (One roll was not enough, had to make a second trip). Tell me what ya think!
-Ryan
-Ryan
