2-old
1. Measure between sunvisor holders.
2. Get an aluminum bar, 1/2" wide 1/4" thick, the same length as the measurement in step 1.
3. Bend aluminum bar to fit the contour of the headliner.
4: Remove sunvisor holders and hold them up to the aluminum bar, and mark where the holes should be. Be CAREFUL to mark the right place on the bar wiith the holder opening away from you.
5. Drill holes big enough for the longer screws to pass through. I used 2" screws.
6. Drill holes in the bar to mount the CB plate on. I used small bolts to fasten it to the bar. I also placed a 1/8 " piece of wood between the bar and roof to protect the headliner
7. Install the bar with the CB attached to the sunvisor holders with the longer screws.
8. I ran the power wires down the driver's A post and out the firewall to the battery and ground.
9. I have a magnetic antenna, so I placed it in the middle of the roof, ran the wire in through the flip window, around the drivers side under the headliner to the CB.
