42RLE Transmission Replacement Pans?
Looks like after trying twice with RTV my OEM pan must be warped because it is leaking again. I give up.:pp:
Time for a new pan of some sort. $10 OEM again... I hope NOT!
Even though I like the idea of steel, the OEM parts are stamped and thin, and will warp easily if they are overtightened pried off etc.
So I am wondering if anyone has a source for a good steel one ?
I found this link for aluminum, have email to them regarding stock size and use with ****** skids, that is a must here. I know aluminum can crack if hit.
http://www.artcarr.com/merchandise/details/39/802.acpp
If you got any ideas for a replacement lets hear about it!
Thanks in advance for info, I do not think there is much available from a quick surf on google though, but maybe someone else has found stuff out there?
Thank You Troy! Going to order one this am!
Here is a direct link with good info (has drain plug) from PML (California)
http://www.yourcovers.com/transpan_11044.php
Note the original post link from ArtCarr in Fl is also from PML
Next topic get a real gasket or just use PVC?
