“GASCAP” in milage window
Puddle Jumper 2.0
Northern Idaho
My 07 Sport is flashing “GASCAP” in the little window on my dash where the milage is usually displayed. Pushing the reset wand next to it clears it up but it must be reset every time it is started or placed in park. I have place a new MOPAR cap on it and reset the codes on the computer and it still gives me that “GASCAP” indicator. Other than some occasional misfires, that new plugs and a new engine/Tran harness has completely resolved (yes I found a factory harness still in its packaging a couple years ago), it gives me no grief. Runs fine with no other discernible issues. Any thoughts out there??? Thank you!
klc
“It flies like a truck.”
PNW
Check the tubing connected to the solenoid under the hood. Mine had a hole worn through the lower one where it passes close to the battery.
CHIPPER146
Try this.
Evaporative Emissions System Leak Detection Pump 310-215​
Around $15.00
and/or
Car Vapor Canister Purge Valve Solenoid​
Around $5.00
Get the parts cannon out. At least these are cheap.
