I got an 02 KJ with the 3.7 v6. It previously had a valve seat come loose and had a valve get stuck due to the loose valve seat. A refurbished head was installed a by a "reputable" engine rebuilding company. When the vehicle got back from the shop it had a ticking sound, the guys at the shop said it came from the gearbox. The vehicle was driven for the next two years without issues despite the ticking sound. However, in early 2023 the vehicle developed a misfire. The same shop diagnosed the car with low oil pressure and said that it could be a worn cam/main/rod bearing causing the oil pressure to drop. The oil is not milky but there is a loss of coolant and the expansion tank is low on coolant, I pulled the valve cover and found that one sparkplug has a milky rusty coating on it and a rocker was slightly loose. I tested the coil plugs with a multimeter and both the primary and secondary windings are within spec regarding resistance values. However there is steam coming from the tailpipe.
My guess is that it could be a blown headgasket/cracked head.
The ticking sound sounds like it is coming from the bottom of the engine, it would be a bummer if it is coming from the crankcase as we all know what that would mean...
Could it be a timing chain issue or a lifter tick ?
I am familiar with working on cars as a DIYer, my first starting point would be to do a compression test to diagnose whether it is a headgasket/cracked head/stuck valve or all 3...Through this. I will also know which bank has the issue.
Any suggestions from the forum members ?
