03KJSadFace
Hey guys from a new jeep guy.
I just picked up this jeep from my sister after she gave up on getting it repaired.
03 3.7 4x4 libby
123k miles
Ran and drove great for years until it developed an intermittent crank no start condition when hot. Eventually it turned into a consistent crank no start condition when hot and even an intermittent stall and misfire condition once fully warmed up.
Shop looked at it and passed it to the dealership.
Dealership ran a compression test which came back fine and a fuel pressure test. 40 psi when running and claimed it was low recommended fuel pump replacement. I am guessing they didn't do a leakdown test on the fuel system (more on that to come).
All sorts of codes were thrown while the jeep malfunctioned from a lean condition to misfire codes to sensor codes.
They ended up replacing the MAP sensor, crank sensor, 2x coil packs, fuel pump, fuel filter, plugs and one more sensor I'll have to pull that info to add later.
So, I get the jeep, see that the cam sensor hasn't been replaced and the pcv valve has a crack. I replace both and it starts up, runs well even when hot. Only thing I notice is a slight bogging down if I idle for 20 seconds or so then immediately floor it. No misfires just a loss of power for a few seconds until it clears up and the jeep takes off. No issues at speed.
I turn the jeep off and still have a crank no start condition when hot. Rock the key back and forth a few times to prime the fuel system figuring maybe its rapidly losing pressure. Viola!!! Success, starts right up! Every time.
Still has the bogging from any period of idle to immediate full throttle but the starting situation has been presumably pinned down. Fuel system seems to be depressurizing almost immediately upon shutdown. Hadn't confirmed with a guage.
Since the fuel pump which apparently contains the return to tank check valve has already been replaced, I pulled the fuel rail to test the injectors and replace the orings. Once I get the rail removed it starts leaking right side from the crossover pipe joint, the orings in there from being moved have now failed. So that nixes being able to test the injectors till that is repaired. I have a new OEM rail coming in and remanned injectors to go along with it.
So my question is. Aside from leaky injectors, an external leak, and the lower fuel pump module check which has already been replaced, are there any other possibilities for fuel to leak internally in the system causing loss in fuel pressure?
I'm hoping that the loss in pressure was due to a leaking injector or injectors and that that was ALSO causing the idle to WOT bogging while the combustion chamber of the suspect cylinder/s burned their excess fuel off.
Anyone with any suggestions? I'm guessing the cam sensor was also causing problems as well as I've seen some wild symptoms of bad crank and cam sensors in these libbys.
Thanks in advance!
Sent from my SM-G950U using Tapatalk
03 3.7 4x4 libby
123k miles
Thanks in advance!
