Boilermaker
- Joined
- Nov 4, 2005
- Messages
- 181
- Reaction score
- 6
Finally finished installing an evic in my '05...thanks to the how-to thread and a bunch of other evic threads from the forum.
Started by pulling out the dome light to find that I didnt have a retainer...but fortunatly thx1138 posted the part number in the how-to thread so i was able to order the part thru the dealership. Next up was running the wires under the headliner and down the A-pillar down to the dash area. I needed a 7/32 deep socket nut driver to take out the bolts in the A-pillar molding. For the fused ignition connection, i just hooked the wire up temporarily to a fuse in the fusebox, there didnt seem to be an easily accessable wire to splice into. The rest of the connections were soldered into data link connector at the bottom of the dash.
Started with an evic from an '02 WJ, and it worked ok...as expected it didn't show the temperature, instant mpg read 0, no tpms and no open door messages. It probably would have worked much better in and '02 or '03 KJ. The WJ retainer is close enough to the KJ retainer that it migh have fit with a little bit of modification, but since i knew i would eventually want to sell it, i didnt go that route.
Found an evic from an '04 on ebay (56010438AD) and it works almost perfectly. Temp readout works, seems like my liberty came with the sensor already installed in the grille. I get all the open door warnings, and I have a 4 tire tpms display...all blank because i don't have sensors yet. I get a warning when i turn the car on about faulty/missing tire sensors, but one button push and it goes away.
The only glitch is that the dome lights come on when they are supposed to be off, and go off when they are supposed to be on. Since i didnt have to touch the light connections, i'm guessing the wiring has changed between '04 and '05. I also wasnt able to swap the lights from my dome light to the evic because they arent the same (i'll post pics of as much of the install as i can if there is interest). I've left the dome light unplugged for now, at some point i have to go back in and run a new set of wires for an autodimming mirror from a wrecked '05 KJ that i also got off ebay.
