stevecon
I got my 05 Libby Renegade from a coworker last year for $500. It had 135k highway miles on it. He put some dough into it - but it had been idled for over a year b/c he bought a new car and he was going to donate it. I bought it for the cost he incurred insuring it. I paid sales tax on the book value of nearly $4k when getting plates for it.
Had either of us known the headaches that awaited - the sale never would have happened. My installs / repairs in the last 14 months and about 15k mi of ownership - in order:
Western Suburban Plow = Moved from my GMC Envoy to Jeep. Need vehicle specific mount & installation. lighting harness - self installed. $550.
Battery - will not hold charge - parts store Self installed $110.
Parasitic battery drain = bad factory radio! - install new aftermarket with SiriusXM, USB, BT, etc. Upgraded all speakers, added tweeters and powered subwoofer. Self installed. $450.
SES#1 = Misfire Cyl #2 - replaced plug & coil pack. Self installed. $20 - $40?
Failed Safety Inspection = parking brake not holding to 1200 RPM - adjusted to hold - barely. $0
Failed Safety Reinspection = parking brake not holding to 1200 RPM - install all new rear rotors, bads, shoes parking brake hardware. Self installed. Just under $200. Excessive passenger-side lower ball joint play - replace ball joint. Shop $300.
Oil under rear differential = leaking seals - replace seals and diff lube. Shop. $400.
SES#2 = Bad Cat Conv Bank 2. - replace Bank 2 cat. Shop. $425
Oil inside rear rims = leaking rear axle seals - replace seals and fluid. Shop. $325.
Failed Emission Inspection. Small Evap Leak.
SES#3 = Small Evap Leak (P0456). Bought factory gas cap $20 - self installed. Diagnostics and underhood evap testing pump. Shop. $400.
SES#4 = O2 Sensor Bank 2 = Diagnostics Shop. $130. Cut out old Sensor, weld new bung, install new O2 sensor. Exhaust Shop. $240.
SES#5 = Small Evap Leak (P0456 - Again!) Diagnostics Shop. $130 No word or cost of repair yet.
Installed LED headlamps $100; replaced factory fog lights $130, replace reverse with LEDs $20, installed add-on LED driving lights below rear bumper for better illumination when backing $50
The wife is not happy - neither am I.. but I feel the Jeep - even without the plow is worth about what I have invested, so not I'm not "upside down" on it really. Besides, snow is coming and I'll love plowing my driveway instead of snow blowing it for 2 - 3 hours each time - or paying someone else to do it.
Would you be "done" or keep with it??
