Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Any help would be appreciated
2008 Jeep Liberty stuck in 4wd
I have a U0431 final drive control module
I have no idea where that is located
The 4wd motor works & ive swapped the switch out & also the ecu
Not a lot of info online on this.
One site did mention that removing the transfer case fuse J2 did get it unstuck.
The dealer has schematics etc and should be able to advise even over the phone where the final drive control module is located.
Here is the FSM 08 Manual to help: https://drive.google.com/file/d/0BwxaBkrMP1bnQWhSUFlCU0JMejg/view
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
