First time in the forum --After driving about 10 km and shutting off vehicle if i try to restart it will just keep rolling over. Vehicle needs to cool down about 10 minutes before it will restart, does it every time. no engine light or codes about 230000km. 09 liberty any suggestions would be appreciated?
I have a 2011 and have experienced something similar. In my case it’s the security system and a failing key or Wireless Control Module (WCM).
When you turn the key to the run position or all the way to start a red dot light will illuminate on the dash for a few seconds and then turn off once the WCM recognizes the key. If the key is not recognize ECU will shut down the fuel circuit. This can happen before the engine starts and just crank or start momentarily and then shut off.
In my case it seems to happen randomly when I run into a store or pickup take out where I shut the engine off and then attempt to restart just minutes later. Like you mentioned, I wait 15 minutes or so then it fires up. I found that only one of my two keys has this issue and just don’t use that key.
Keeping an eye on the security light on the dash might help show if this might be your issue.
