'09 KK 160,000 miles:
My daughter was on her way home from school yesterday, and stopped at a light. When it changed and she took her foot off the brake, she said the jeep just rolled backward. It wouldn't drive forward. Long story short it got towed home. But she said the engine seemed to run fine. But when it came off the tow truck, it won't stay running at idle.
So, this morning I've been working on it, and here's what I've found.
- Engine struggles to start, and when it does it surges up and down and will die. Does not smoke, or backfire.
- Holding the throttle open at between 1500 - 2000 RPM it will run ok-ish
- Sometimes will rev over 2500, sometimes refuses even with your foot to the floor.
- No engine codes. I'm using the JScan tool, and did the deep-dive scan, still no active codes.
- Pulled each spark plug, all look fine. Dry, and gapped correctly, and look to be running fine. One maybe looked ever so slightly lean.
- Got a fuel pressure gage at parts store and tested pressure at fuel rail. Consistent 58 psi.
- All hoses look fine.
- Visual inspection of Throttle Body seems fine
- When I run the Live-Data using the JScan tool, I'm seeing just one or two miss-fires
- Here's the live data when I'm holding the throttle open between 1500 - 2000 rpm
- Barometric Pressure 15psi
- Throttle Position B - 18.43%
- Throttle Position D - 9.02%
- Throttle Position E - 4.31%
- Ambient Air Temp - 57 F
- Calculated engine load - 0.0%
- Catalyst Temp Bank 1 - 1297 F
- Catalyst Temp Bank 2 - 1297 F
- Commanded EGR - 0.78%
- Commanded Evap Purge - 0%
- Commanded Throttle Actuator - 7.84%
- Engine Coolant Temp - 148 F
- Engine RPM - 1877 RPM
- Fuel Air commanded equivalence Ratio - 1.00
- Fuel Tank Level Input - 42.75%
- Intake Air Temperature - 66.0 F
- Intake Manifold Absolute Pressure - 7.00 PSI
- Long Term Fuel Trim - Bank 1 - 0.0
- Long Term Fuel Trim - Bank 2 - 0.0
- Oxygen Sensor 1 (short term fuel trim) Bank 1 Sensor 1 = -32.81%
- Oxygen Sensor 1 (Voltage) = 0.21v
- Oxygen Sensor 2 (short term fuel trim) Bank 1 Sensor 2 = 99.22%
- Oxygen Sensor 1 (Voltage) = 0.84v
- Oxygen Sensor 3 (short term fuel trim) Bank 2 Sensor 1 = -32.81%
- Oxygen Sensor 3 (Voltage) = 0.78v
- Oxygen Sensor 4 (short term fuel trim) Bank 2 Sensor 2 = 99.22%
- Oxygen Sensor 4 (Voltage) = 0.86v
- Relative Throttle position - 5.88%
- Run time since engine start - 30sec
- Short Term Fuel Trim (Bank 2) = -12.50%
- Short Term Fuel Trim (Bank 1) = -15.62%
- Throttle Position = 17.25%
- Timing Advance = 25 DEG
I'm stumped! Any advice would be REALLY appreciated. I'm not even sure what to check next. I was able to keep the engine running long enough to put the jeep in drive and move it around the driveway a bit. So I do have drive, at least a bit. All fluids are topped and look fine. Nothing dripping (more than usual!)
