Ok, after much testing and such at this point I have it back out with just the head unit. I was just getting way too much interference from something while listening to the radio on AM. I like listening to hockey games at times when they are on. Also, baseball in the summer. I don't know why I was getting so many weird noises, but they seemed to be coming from all the wiring under the dash. The blinkers made noise and random things turning on and off did too. I ran a separate fused power line and grounded to my own grounding post I created under the dash, which may itself be the problem. Does anyone know a really good ground under the dash or behind the kick panel?
This is what it looks like lit up:
This is what I did to the previously mentioned faceplate:
and then also what I needed to do to match the curve in the radio/instrument bezel:
Looks nice. It is sort of a love hate item at this point. There's almost too much to control with 7 bands of EQ and a sub plus a fader. It really is overwhelming if you don't have a good amp, which I am now saving for.
You really need a dremel to alter the faceplate and make that curve on the EQ corners itself.
To mount the EQ I simply zip tied it together with the head unit and put that friction material between them so it wouldn't slip. It really worked good and was solid. Just have big zip ties and pull those suckers as tight as you can. I didn't want to hassle making brackets; just seemed like overkill.
as for fitment, it is EXACTLY 1.5 din. You have ZERO room to work with and it is tough to get all the wires I have behind there. I have a USB cable, iPod cable, aux cable and then a noise suppressor all jammed in there, plus rcas for the sub and front and rear channels. You need to route stuff strategically in order for the bezel to fit right again. Luckily there is a lot of room to the sides of the radio area. So, does it work, yes for me right now the way it is no.
too much to do, eq wise
too much noise so far, need to investigate why
frustrating to say the least at times
fun? yes
