Wish I had found this site sooner cuz I think I messed up. Bought a set of 245/75/17 tires with wheels from a 2015 Wrangler for my 2005 KJ Renegade. Of course 1st thing I realize is the new wheels are 5x5. Before I look at adapter/spacers, etc., can anyone tell me if these wheels & tires are just not going to work on my KJ? I'm not opposed to lifting (up to 2.5") cuz I probably need new shocks and springs anyway... Any help is much appreciated.
(wheels 7.5" wide, 5.75" backspace if I measured right)
What’s the overall height of your tire, in the photo that I posed it looks like their might be some clearance issues.Same question from me too. I already bought them and now I don't know if they will fit without major work.
I just put some on my 2006 CRD which I picked up brand new for $500. Gotta love those vain Rubicon drivers. I have a 2.5 lift. Because the lift still left the front lower I custom made a 1.5" spacer out of UHMW which helped on the clearance. I picked up the 1.25 wheel adapter spacers on eBay for not much $$. However even with that I still got a bit of rubbing. If you're not afraid to do some modifications to the wheel well they will work fine. Trimmed up the front plastic and folded the pinch weld... do not ever cut the pinch weld. Power wise it's fine, but then I'm running a custom map on the trans and ECU. Cruse on the highway at 1800 RPM at 70 mph... 28-30 mpg. So ya, you can do it. Just don't think it's plug n play.Would require adapter spacers due to the different lug spacing. While some run them with no problem they're not usually recommended. It's always better to just get wheels that actually fit.
I do like the way that looks convertable, but I wouldn't do it unless also adding a full cage/frame, which would require more power to handle the weight, which would require more robust running gear, which would cost lots of time and money, which i don't have much of either, sooo I'll keep the roof.
Yes. It’s the studs they use in them are super sketchy. I’ve snapped off using a 4 way bar on someone else’s truck. Eeekcheap ebay spacers LOL
Yes I sure would trust my life with them NOT
