2005 2.8crd engine coolant water leakage
cn klt
Hello All,
I m suffering from the engine coolant water leakage problem... ( vehicle at 95.000km )
I have to add 1 liters for each 1000km.
We have checked/tested the head gasket it is ok
I can not see the the leakage..
could you please help me and share with your advice's?
thanks,
Any strange smells in the car when you put the heating on first thing in the morning?
Check everything for the crusty stains of a cooling system leak, especially the radiator and the bottom of the cam belt cover, the water pump is inside & driven by it.
Don't put anything except HOAT antifreeze in, it's a wet liner engine and standard coolant will wreck it!
Sevenmilesout
Montpellier
I had the same problem with my 2.8 crd. Not a huge loss of coolant, but enough to bother me. I replaced the reservoir cap about 12 months ago & since then....no coolant loss.
