Somthin's up with my jeep lately. Start it cold runs & sounds fine but you can feel a slight shake. I pop the hood, and ya the rear cylinder breather hose is shaking good.
If you leave the driver's door open and put your hand on it, you feel it vibrating= eek.
So I let it warm up, not as bad but still a slight shake.
In Park under hood, I manually at TB advance the throttle to about 2000 rpm and ahh..you can feel a stumble even at 1800- 2000.= eek.
SO I hop back in drivers seat, giver so some gas quick up to 2500 rpm and release...ahh..pop..pop in exhaust is heard..= eek.
Pop pop in exhaust to me means ...somethin is slightly sticking, probably the lifter department, and we know what comes next if the lifter/ lash adjuster does not compress within spec right..?? ya..fling..click- clatter as the rocker comes off.
I also know that sludge or dirty oil can cause problems. We dont have any sludge in our oil fill tubes right!!??
Pulled a few spark plugs, all look good, checked gap, no codes, throttle body is clean, PCV is new, oil is new synthetic.
So I am not a big fan of adding anything to my oil, as we know snake oil is not recommended, but at this point I will try anything.
So I drain about 1.5 liters of the clean oil out, and here goes the mixture.
One can of Wynn's Engine Tune up/cleaner and 3/4 of a liter of Marvell Mystery Oil.
51885[/ATTACH]"]
Out for a 1 hour hwy boogie I go...
Ah...what a difference...Hardly any shake & as I advance the throttle under hood now to 2000 rpm ---No Stumble. :gr_grin:
I expect the oil will get dirty quick as it cleans and will change to new again in 500 miles.
I hope this cleans the valves/lifters well. How much crud is in there?
51885[/ATTACH]"]
