HULL_IN_KK
- Joined
- Apr 18, 2025
- Messages
- 4
- Reaction score
- 4
Thanks for the reply. I had read this, even some installing new springs and shocks and being satisfied with the height of the front even without the spacers. 103,000 on my jeep so probably about time for them anyway.Yes, I have a pair of 1/4" fitted, the give around 1/2" lift..... however they aren't going to fix shot springs, if you have a low front you really need new springs and probably shocks too. Worn springs give a horrible ride and pound the bumpstops.
Sounds good. I'll probably replace the struts up front and see where that gets me first. Don't need a ton of clearance where I reside, very flat mostly gravel...not a lot of great spots to test a jeep out.I've got H&R springs with the weight of the 2.8 Diesel it needed the spacers to give it 20" on a V6 you should get 1 1/2"
Mine is a KJ, a KK is very similar front suspension so I guess the results will be the same.
