If your KJ only has 2wd,4hi(part time),and 4low selection then you can only use 4wd on slick surfaces.Wet pavement is still a high traction surface.Lol. I was on pavement but we had some snow and ice. I come from the hummer 4x4 system that was full time 4 wheel drive. Ill need to do a little reading up on the jeep 4 wheel drive. Thanks for the help guys.
Quick question four the group. I have an 08 jeep liberty 4x4. When I put it in 4 high it drives fine till I try and turn the wheel, it will turn but it's pretty tight. Is this normal? Thanks, Adam
You have a D30 sized front diff and the rear 8.25 which have different size ring gears so the gear ratio's will not be the same front and rear.They will be close,within 1% and some vehicles up to 5% difference.If you swpped 4.10's in your Liberty you actually 4.09's in the front and actual 4.10's in the rear.Thus even driving in a straight line you will still get driveline bind in 4wd(part time or 4low).so just out of curiosity...technically if you are driving in a straight line, you shouldn't have binding issues even on a high traction surface, correct? I don't have any plans on doing it....but just so I can understand why binding happens a little better. My understanding is that your front tires are spinning at different speeds when you turn in 4wd, which is controlled by the front differential...so one the wheels need to be able to slip when turning. But if you're traveling in a straight line, the wheels should be spinning at the same speed and not bind up right? Also, what is the mechanical difference of full-time 4wd that alleviates binding? It is just an additional differential between the front and rear, as opposed to locking the front and rear driveshafts together?
(I know he was asking about turning, but we've answered the "why is it hard to turn in 4wd?" question about a million times on here already...so figured I could try to learn something semi-related)
