about glow plug relay/module
cn klt
Hello everybody,
My glow plug relay has problem, I got P1261 fault
I need to know that, what is the part number of glow plug relay ? Because I con not find the original relay ( bosch : 0 281 003 034 )
is there an alternative part that I can use instead of the original relay?
thanks,
I think it's obsolete, the replacement one should be a 083, also used in VWs so should be easier to get.
cn klt
thanks, if I use it ( 083 ) do you know that is it necessary to make a modification in the ECU software??
I'm sorry I don't know, I suspect its just plug and play though.
