ABS/Speedometer Issue
GunnerSchenck
Hello all,
I have a 2003 sport 2x4(yes, unfortunately) but thats not the issue at hand.
I recently changed my front hubs/bearing assembly because they've been bad for awhile.
Went fine, but after driving for about 20 miles, the speedometer quit and my abs, parking brake turned on, followed by the check engine low a few miles after.
My first thought was the abs sensors on the hubs i installed were junk(as the parts were cheaply ordered [Detroit Axle]), so i got new ones from 1AAuto.com and installed them.
Everything went fine and the bearings ride awesome.. even better than the other new ones.. but one thing, the lights stayed on and my speedometer stayed off.
So i pig-tailed in(with heat shrink splice connectors) the car side of the abs connector on the drivers side in the engine bay. Assumed perhaps it wasn't staying connected as it was very brittle and slightly broken when i took it apart from being off its designated stud and sitting next to the engine.
But the new connector changed nothing.
So i checked all the fuses, and not a single fuse blown in the car.
Reset the instrument panel(turning vehicle to on while pressing the odometer in.. vehicle was off though)
Any ideas? Can i test the continuity/resistance of the abs sensors if i take them out of the wheel hubs? could changing these i have accidentally pulled on the wiring for the abs connector at the rear axle and loosened it?
Any ideas are greatly appreciated. Thank You.
