AC not blowing cold
Rstep21
Florida
Good day, my 06 Liberty just stopped blowing cold air, it has a completely new system that is about a year old and worked fine up until yesterday. The compressor is coming on, the high side line is hot and the low side line is cold. I connect a gauge and it shows the Freon is good based on the gauge. I wonder if the blend door is partially open to the heat side. Let me know what else I am missing so I can get this cooling again. Thanks.
Pgy
Mine had the same issue and they refilled the freon ( checked for leaks but didn't have any), after that it worked like a charm.. I don't know if that helps with your issue but i just thought it's worth mentioning.
Found the issue, my daughter was messing around and I did not realize she changed it from recirculating to outside air. Lol
Thanks for the help.
The A/C should still work even though its pulling in outside air. You'll certainly notice a decrease in performance, but it will still work.
I actually prefer outside air if other people are in the vehicle. I get a bit claustrophobic when Im in close quarters with other people.
