ac problems
fbruce4782
fort worth texas
i am hoping that some one can help me i have a 2007 jeep liberty the ac compressor looks it is leaking oil out around the shaft it collecting on the clutch should i go ahead and do a bypass on the ac before it locks up
Kidketchup
Canada
Technically, the compressor clutch should not engage if the leak is enough to loose the gas or pressure. If you won't take a chance, you can apply the bypass or disconnect the electrical wire on the compressor. The second solution means that you don't have any issue with the clutch bearing but only a leaking issue.
Envoyé de mon SGH-I317M en utilisant Tapatalk
