ac wont blow cold
russellbax
benton, ar
I,m a new member. I have a 2005 liberty 4x4. Ac wont blow cold air compressor clutch works Freon level good fam works just replaced pressure switch. Why wont it blow cold.
Kidketchup
Canada
Did you check with gauges low and high sides? I don't know if it could be the expansion valve but reading with gauges will be a good start to diagnose. Look at "eric the car guy" on YouTube for better idea on how to diagnose.
Envoyé de mon SGH-I317M en utilisant Tapatalk
ouroboros
Montrose, MI
Your best bet (Since there's no true way that I've seen to check freon levels) is to have a recharge machine hooked up to your Lib so it can do a vacuum test. If it passes the vacuum then freon can be shot in along with a UV dye, drive it for a few days and run the AC some if you can and bring it back to whatever shop you get it done at so they can find the leak. Hard to say where it could be coming from without physically looking at the Jeep. Could be the compressor, condenser or an AC line somewhere along the way. Seriously doubt it has anything to do with a pressure switch if it's blowing air through the vents. No freon = No AC
EDIT: Do not use those cans of freon you buy from the parts store. Not only is it a dumb idea and can over pressurize the system and could potentially further rupture any lines that may be leaking. I believe the 3.7 call for 1.37lbs of freon.
ouroboros
Montrose, MI
Just for reference I personally use the Snap On Koolkare Plus at work for AC charging and problem diagnosis.
