I just tested my cooling system. So..No A/C on temps rise to 217F where the electric fan automatically came on.
With fan now running, it shut off at 212F and with fan stopped, cooled back to 200F pretty quick.
I guess the system is working as it should. As far as they 2 relay's, going to have to look into that. If my fan was running at high speed, really did not seem like it.
Going to have to check things out a bit more closely here.
Why did jeep want the electric fan only begin to kick on at 217F? That seems a bit high to begin the cooling process..?
Maybe I should install my own fan switch, to get the fan working when I want !
Would be nice to have it run for a few minutes once you turn the Jeep off too.
Found photo of 2 relays hi-low, looks good so far. #15 btw was highlighted as a power removing storage fuse.
61694[/ATTACH]"]
