J Lib
Hello all,
Thanks for taking the time to read my post!
I have a 2004 Liberty 3.7L with only 242,000 km (150370 m). It runs like a charm but there is one issue I can't seem to put my finger on. When the vehicle is warm and I run the heater, there is this slight antifreeze smell. I only seem to smell it when I set the temperature dial anywhere in the red zone of the temperature setting. Anywhere on the blue part of the temp setting and the slight smell starts to go away. This has been happening since the fall of 2023 when the temperature started dropping and I started using the heater to present time. I have not found any moisture on the carpet or puddles on the the driver or passenger side floor, seen any obvious leaks, nor have I had to add any antifreeze to the degauss bottle. I just want to mention, the antifreeze was flushed June of 2022 and replaced, like usual with Mopar HOAT.
Has anyone experienced a similar situation as this and what was the solution?
Thanks in advance!
J Lib
Thanks in advance!
J Lib
