I know exactly which knob Socks is referring to, but can't seem to find that one listed for sale anywhere. I did, however, find these knobs. The only problem is that they are for a manual transmission. I'm sure you could modify the stock shifter to make it work with a manual knob, it would just be a little dangerous due to you no longer needing to press the shift button to shift the transmission, but anyway here you go:
Red
Blue Base w/ Silver Top
Blue
Yellow
4 buttons for all your switching needs\\
/ (including OD)
Not the same as the one I was talking about.
But.
The one I had in my hands was actually pretty decent looking. All aluminum construction with a polished lower half, a satin "brushed" top with a smoked or coloured plastic "Push to open" switch cover.
And it was for an automatic transmission, complete with a button for the electronic overdrive.
The instructions actually indicated that relays were needed to operate the switches as they were low current draw.
Like I said, I'll be going to that store later this week or up coming weekend.
They have two locations here in the Greater Vancouver area, one store carries them and the other branch does not. Go figure!
Cheers
Ry'
At which time I'll try and get the name, address, website, etc.
And, as I mentioned, it had four (4) accessory buttons which you could assign for what had you!
