On my 04 Renegade (fitted with stock wheels) I get the bad/missing TPMS sensor upon each start up. Tire pressures in all 5 tires are good. The EVIC displays the pressure for all 4 tires (R front, L front, R Rear, L Rear). The spare never displayed. I was able to retrain all 5 TPMS sensors with the magnet (don't understand why if one is bad) and I still get the error message upon start up. Which tire is the problem? I'm guessing the spare since all 4 rolling tires display pressures in the EVIC. I assume I'd see a -- in the bad tire on the EVIC. I don't feel like buying 5 sensors at $60-70 each. Any input (searching did not identify a resolution).
Thanks.
UPDATE: I ran the diagnostic test as follows:
Scroll to the blank display by pressing the STEP button.
Press and hold the RESET button for 5 seconds.
The EVIC will emit a beep to indicate the start of the test.
The EVIC will clear the sensor signal counters.
The vehicle icon will be displayed with transmission counter at each corner.
Drive the vehicle at speeds above 25 mph for 10 min.
The counters will increase by one each time a sensor signal is received by the EVIC (approx. 1/min from each wheel except the spare).
The test will continue until any EVIC button is pressed or until the ignition is cycled to OFF.
I think it's my spare - read zero after 30 minutes of driving.
Thanks.
