yellocoyote
It's been an interesting day...
Last night on my way home from class, the battery light came on on my dash. Drove all the way home without problem. Once home, I had Aaron check the volts with his scangauge. The gauge showed more volts without the engine running (12.1 volts) than with the engine running (11.4 volts), so we assumed the alternator was the culprit. I stayed home today, and we changed the alternator.
Battery light still came on.
I went to class tonight without a problem. However, on my way home the dash lit up like a christmas tree... all the 'idiot' lights were blinking, the radio shut itself down, headlights dimmed and eventually shut off, windsheld wipers stopped working. With it being dark and rainy, I pulled off and called Aaron for help. Once I shut the engine off, I was unable to get it to start again. Aaron brought the van, and hooked up the jumper cables to the kj's battery, and got it to start... but it wouldn't stay running unless I kept my foot on the accelerator a bit. At that point I decide to make a run for home (5 miles away). Only got a couple miles down the road when all systems in the kj died again.
We removed the battery that was in the kj, and went to have it tested. It tested bad, so we got a replacement for it. Installed the new battery.
So, now I'm stuck. I'm thinking that it would be wise to check the battery cables... but what else should I look for? I've never experienced anything quite like this with prior vehicles before.
