Best aftermarket radiator
Jasonmc
Looks like this has been discussed slightly in other threads but I was having issue finding a good opinion. What is the best aftermarket radiator for 06 Jeep Liberty with external trans cooler and no Eng oil cooler? It seems mopar doesn’t make that one anymore. Thanks
Quite a number of aluminum ones out there now, folks seem to be having good luck with them
duderz7
Weiser, ID
I picked up a mopar one from Amazon not long ago for about 210. Haven't put it in yet. But looks good. Has ports for trans cooler as does the original, but they are not being used as I also have the tow package.
The original mopar rad in your 05 had trans cooler ports? If thats true, thats odd, b/c I thought only the 2002 and some 2003s had that. I just replaced the rad in my 04 with a mopar rad and it does not have those. I always wanted a mopar rad with them for the additional cooling, but after adding the PML pan and the mechanical cooling fan, I really dont need it.
duderz7
Weiser, ID
Yes, the ports are there, I suppose I cannot say for sure it wasn't replaced earlier on as I am not the original owner. I also don't see a chrysler or mopar indication on either one.
