Bashgod
any help? i think i heard something about 265-267 mm cams from mopar... ill check out.
why.....
iirc, one of KY Liberty's posts said the Fastman might be able to help you with cams.talk to kyliberty, hes knows all about that stuff..
What year KJ do you have? If you have a mid year '03 or newer you will need major ****** work done,the 42RLE won't live behind that power.Also sorry to say you'll be needing way more than then forged pistons and rods,and new harden steel crank will be needed for the engine to last,and those are not cheap($2500+).The 3.7 is just not ment for high HP,for the money spent trying to get 400HP from a 3.7 you could swap in a 4.7 and do some light mods on that and be at your HP rating for probally less.Or if you want to get really fancy you could shoe horn a 6.1 HEMI in and get 610HP for $20,000(plug and play),but then to you would need ****** mods and rear end mods.thanks guys. I want bigger cams because I want more power, bigger cams can be designed to give more low end power or top end power. personally i think my liberty needs more top end. I am slowy building up my jeep I have a full exhaust, new intake, with a Jet stage II chip, 93 octane gas, fastman throttle body on the way.
The liberty is no sports car and neither is a Civic, Integra, or Celica but how many do you see with 400+ horse power.
These upgrades are small steps to the supercharger i plan to install, after i get forged piston and new aluminum rods. I hope to run it at 15 psi with 400+ hp to the wheels... after my lease is up of course lol.
As far as gas mileage is concerned it is obviously a compromise im willing to make, more power needs more fuel...
But it would so much cooler saying----"Yep it's got a HEMI"----!!!!!!!!its a 2007, headers and all the rest of that stuff are on the list. the supercharger and future plans (years down the road) and by the time i have all the money I might want to do something else.
Calm down all you nay sayers, I appreciate the advice and am taking it into consideration but I really want to stick with the 3.7 as pointless as it may be. I would like the satisfaction of saying "yep a 3.7 v6..."
I don't see the point either, more aggressive cams will only make sense at high rev's...which means you lose power (compared to the stock cams)/ poor running engine at low rev's. Which you use the most offroad...
If I had a V6 and bunch of $$$ I would go for bigger pistons...
Do it and have fun.
My advice would be simple. Use quality parts that you won't have to swap out later on. Dryflow intake (cold air if available), long tube headers (if available), Gibson exhaust with mandrel bends or other mandrel bend system (2 1/2" should be plenty big), Reprogrammed computer, and underdrive pulley (be careful of ASP).
After doing the easy bolt-ons you can decide to stop there or move up to forced induction.
That's what I'd do.
From my limited knowledge on the 3.7, I'd think the biggest hurdle is from lack of PCM tuning. Cams and mechanical parts can be fabbed up.
I'm not sure on the capabilities of the 3.7, but there are GM 3800's (push rod 3.8L) that a supercharged that are running 11's in daily drivers in Regals and Grand Prixs. A properly force-fed V6 isn't anything to laugh at for sure.
