My 05 Liberty with 75k on the odometer was riding a little loose . Installed a set of Bilstein shocks front and rear as well as an alignment . Greatly improved ride and directional stability . My driving is strictly on-road but with a stock suspension they should handle whatever off-roading you also do . I've used Bilstein's in the past on different trucks and this set for the Liberty is just as good . The rears are an easy install( 2 bolts each) but the fronts require the struts be removed from the "JEEP" and a suitable strut/spring compressor . If your not used to wrenching this is a job better left to a pro shop .
