tazzman45
ok so I have a 04 liberty 3.7 2wd my wife accidentally put power steering fluid in the master cylinder so she got a turkey baster and removed it but not before she had to drive it to buy one long story short the front brakes locked up on me so I had to replace the brake hoses on the front and went ahead and replaced brake pads since I was there good for 2 days then same story they locked up on me got it home and replaced both front calipers and also flushed all the brake fluid it is completely new fluid but the brakes in the front is still locking up after it's been driven for a while it feels like the pedal just keeps building the more you use it getting harder and harder but if you let it set for a little while its all back to normal does this sound like the seals are messed up in the master cylinder and not letting the fluid back to this reservoir is there some place I could get just the kit to rebuild the master cylinder? money is very tight at the moment my iob has cut my hours so i'm trying to fix it but have little money could I go to a salvage yard and get one as long ass I make sure it has fluid in it until I can get the money for a new one which is like 100 anyway thanks for the info
