Build sheet questions
majikkj
Versailles, KY
Could anyone clue me in on what these two codes are. I couldn't find any info on them. Thanks.
2TGA - Customer Preferred Package 2TG
28G - Customer Preferred Package 28G
P.S. Thaks for a great site:)
hyde
There are 4 packages.
B, C, F, G packages.
Each one has options packaged together with "package savings" at the end. If you got your jeep new, you can see your window sticker for more info and savings for package, versus added seperately.
For more info on packages and comparison, please check here:
http://www-5.jeep.com/vehsuite/VehicleCompare.jsp
and select packages, then you can extend features at the bottom. (Tires, Transfer Case, etc...) to see whole feature comparison chart.
majikkj
Versailles, KY
Are these just for new Libertys? Mine is a 2004 Limited. Guess I could have told you that from the beginning. I see the packages but there are no codes listed. Any more help would be greatly appreciated.
hyde
Almost same thing. I have 2004. I think i have F package.. gotta check what I got. But they changed a bit, only radio, ESP, and a few interior stuff changed from 04 to 05.
The codes won't be there, as they are only for the build sheet code. I think Titan had 28G package? I forgot. We have to find a window sticker for you.
majikkj
Versailles, KY
Cool. Where can I find a window sticker. I could have never imagined that these codes could be so much trouble. ](*,)
hyde
OK, JeepJeepster has GOT TO KEEP his window sticker.
He has 28G package. He will post his stuff. :) When I come think of it, I also may have G package and not F, I have to check.. If for some reason he doesn't have his, I will scan mine for you. :) What color KJ do you have?
My built sheet is somewhere here.. Edit: Found it: http://jeepkj.com/forum/showpost.php?p=289971&postcount=8
I think sunroof, mirrors, heated seats etc..
majikkj
Versailles, KY
We have almost the same kj barring the color and a couple other things. Mine is Light Khaki. Here's my build sheet:
*DL - Prem Leather Trimmed Bucket Seats
-L2 - Light Taupe
AHMS - Convenience Group I
AJBP - Security Group
AJPS - Power Convenience Group
APAS - Monotone Paint
A90P - 3.7L Eng (EKG)/4Spd A/T 42RLE (DG6)
BAZS - 136 Amp Alternator
BC2S - 600 Amp Maintenance Free Battery
BRES - 4-Wheel Disc Brakes
CF5S - Rear 65/35 Folding Split Seat
CGUS - Child Seat Anchor System-LATCH Ready
CG1S - Next Gen Multistage Front Air Bags**
CKDS - Floor Carpet
CKNS - Cargo Compartment Carpet
CKTS - Cargo Tie Down Loops
CK3S - Plastic Swing Gate Trim Panel
CLES - Front & Rear Floor Mats
CLHP - Cargo Trim Panel w/Storage Net
CSAS - Spare Tire Cover
CSCS - Cargo Compartment Cover
CSRS - Passenger Assist Handles
CSWS - Driver Assist Handle
CTCP - Luxury Door Trim Panel
CUDP - Mini Overhead Console
CUFS - Full Length Floor Console
DGBS - All 4-Speed Automatic Transmissions
DG6 - 4-Spd. Automatic 42RLE Transmission
DHAP - Lock-Up Torque Converter
DHPP - Selec-Trac Full Time 4WD System
DJJS - Dana 30/186MM Front Axle
DMES - 3.73 Axle Ratio
DRAS - Corporate 8.25 Rear Axle
EKG - 3.7L V6 Engine
GBBS - Tinted Windshield Glass
GCBS - Front Door Tinted Glass
GEGP - Deep Tint Sunscreen Glass
GEKS - Flipper Swing Gate Glass
GFAS - Rear Window Defroster
GNCP - Sun Visors w/Illum Vanity Mirrors
GNKP - Rear View Auto Dim Mirror
GTSP - Power Heated Mirrors, Fold-Away
GVBC - All Vehicles W/Power Mirrors
GXMP - Remote Keyless Entry
GXXP - Sentry Key Theft Deterrent System
HAAS - Air Conditioning
JA2S - Instrument Cluster w/Tach
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JHBS - Rear Window Wiper/Washer
JJBS - Dual Note Electric Horns
JJJS - 12V Auxiliary Power Outlet
JJMP - Auxiliary 12-Volt Rear Power Outlet
JKYS - Power Accessory Delay
JPHP - Speed Sensitive Power Locks
JPM - Heated Front Seats
JPTP - Power Front Driver/Passenger Seats
JPYS - Pwr Windows, Front 1-Touch Down
K2KS - STRIPE/BADGE/MOLDING/COLOR
K5KS - STRIPE/BADGE/MOLDING/COLOR
LACP - Illuminated Entry
LAZP - Vehicle Information Center
LBBP - Courtesy Lamps
LCDP - Map/Dome Reading Lamps
LDBP - Cargo Compartment Lamp
LETP - Traveler/Mini Trip Computer
LHDS - Headlamp Off Time Delay
LMAS - Halogen Headlamps
LNJS - Fog Lamps
LPSS - CHMSL Lamp
LSAP - Security Alarm
LSES - Enhanced Accident Response System
MDAS - Front License Plate Bracket
MFKS - Body Color Grille
MLAS - Body Color Fascias
MSUS - Limited Edition Badge
MVCS - Jeep Badge
MVDS - 4X4 Badge
MWES - Side Roof Rails
MZLP - 3.7L Badge
MZ3S - Liberty Badge
NAS - 50 State Emissions
NB5P - Federal Tier 2, Bin 5 Emissions
NGAS - 19.5 Gallon Fuel Tank
NHFS - Power Steering Cooler
NHMS - Speed Control
PJC - Light Khaki Metallic Clear Coat
QJCS - Light Khaki Metallic Clear Coat
RAAC - All Radio Equipped Vehicles
RBPP - AM/FM Cass/CD Radio w/Changer Ctrl
RCJP - 6 Premium Speakers
RDDS - Fixed Long Mast Antenna
RDZP - Steering Wheel Mounted Audio Ctrls
SBAS - Power Rack and Pinion Steering
SCGS - Leather Wrapped Steering Wheel
SDAS - Normal Duty Suspension
SUAS - Tilt Steering Column
TBBS - Full Size Spare Tire
TBRS - Outside Tire Carrier
TSN - P235/70R16 OWL All Terrain Tires
TZAP - Goodyear Brand Tires
WKBS - Matching Spare Wheel
WLDS - 16X7.0 Lux Aluminum Wheels
WLZC - All Aluminum Wheels
XCAS - Occupant Classification System
XGDP - Universal Garage Door Opener
XGGS - Grocery Bag Hooks
XGMP - Tire Pressure Monitoring Display
XJFS - Tethered Fuel Filler Cap
XPFS - Protective Coating and Remover
YAAS - Build To U S Market Specifications
YEP - Manuf Statement of Origin
YGEA - 5 Additional Gallons of Gas
ZCHP - Spring - Left Front
ZCVP - Spring - Left Rear
ZRGP - Spring - Right Front
ZRVP - Spring - Right Rear
Z5BS - Payload Rating - 1800#
1AAS - U.S. Dealer Retail
142S - Zone 42-Detroit
3VTA - Customer Preferred Discount
5I4S - Four Wheel Drive (4WD)/(4X4)
5I8S - Left Hand Drive (LHD)
5YAS - KJ-Vehicle Family
594S - Vehicle Order Tracking
6USS - Label - U.S. Specifications
636S - Ohio State Code
936S - Ohio State Code
I have the 28G package but mine is an 05. Still, it looks pretty much the same as what you posted Hyedipin except I don't have the cigar lighter and ash tray. Looks like it didn't change much.
There is a site - cars.com - where you can put in any vehicle and get specs and options and it lists the option packages/standard equipment/models/specs/prices etc of all vehicles. This might also be helpfull.
tan's2002kjlimited
Chicago suburb - Hanover Park IL 60133
-L2 - Light Taupe
CKDS - Floor Carpet
LNJS - Fog Lamps
LPSS - CHMSL Lamp
MVCS - Jeep Badge
MVDS - 4X4 Badge
MZLP - 3.7L Badge
Wow! That's more typing than my gnarly ol' fingers would be willing to do!
