2006 Jeep Liberty limited. 3.7 selec trac. I have the front differential out and have stub cv ends in just incase. Trying to find the right bushings so I can replace them on all the mounts. Last time I shifted into 4 full the front end felt very rough like it didn't shift to 4wd so the way, this was before I had the diff out. The shifter cable is attached, fresh fluid in case. So now I want to have the transfer case worked on. Question I have is there a bypass out there where I can remove the transfer case so it can be worked on so I can still drive. Something that will replace the transfer case and still let the rear driveshaft connect?
