Can the cluch safey switch be replaced without removing the master cylinder? Jeep seems to sell the clutch hydraulic unit with the switch on it, but a lot of the aftermarket ones don't seem to include it, and look like you just attach it to the road coming from the pedal. I see the switch can be purchased separately, and it looks like it would just slide on, but I can't find anything showing it's replacement to confirm. The transmission shop who replaced my hydraulics a while back screwed up the switch. It was intermittent at the time so hard to prove to them. It's been getting worse and worse. I need to find just the right position for the clutch pedal now for it to engange. I know I can bypass by going into 4 low, but I also have a problem with the linkage for that popping off. If it can be replaced easily, I am going to do it, but otherwise, it may just get a jumper wire.
