Can't find part numbers for these bolts
jaytango
orlando
I'm almost done with my 4x4 conversion. I'm only missing the following bolts/nuts and I can't find the part numbers anywhere on any chrysler or mopar sites.
Bolt and nut for front axle bracket isolator:
https://www.factorychryslerparts.com/productSearch.aspx?searchTerm=52125142AC
Bolt and nut for front axle passenger-side isolator (#3 in diagram below):
Bolts for front axle rear dogbone isolator (#2 in diagram below):
https://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=576452&ukey_make=1064&ukey_model=15531&modelYear=2010&ukey_category=20306&ukey_driveLine=7561&ukey_trimLevel=18760
I'm about to give up and maybe get something from home depot but I don't think they carry bolts that are the right grade. Any suggestions?
jaytango
orlando
Oh man, thanks! I'm gonna make a run to HD or Lowes and see what I can find. At least I can get everything mounted and running while I continue to look for the stock bolts. I've got the rear-end installed already (trans. extension/shaft, transfer case, & rear driveshaft). I can't record the final footage and upload the project video until everything's in place. I won't be doing any crazy trails for now so I think the grade 8's should work. Thanks man.
