slamgranderson
Hi, I've had an engine light that's been bugging me for about a year now. The code is P0302 or cylinder 2 misfire. Here's what I've done: replaced all the spark plugs, replaced the fuel injector for cyl 2, and swapped the ignition coils with another cylinder to find out if it was the coil - it wasn't, when I put the coil from cyl 1 on cyl 2, there was still a misfire on 2. The engine doesn't run rough, and the misfire is not consistent. If I clear the light, it will run for about 100 miles before the light comes back on. It doesn't affect performance enough that I want to waste money of having a mechanic diagnose it - it seems to run fine as is (although it doesn't get the best gas mileage). Nevertheless, engine lights are annoying and I'd love to get rid of it. Any thoughts or ideas on what this could be? [2004 Jeep Liberty v6 w/ 118k miles]
