Center console upgrade?
teeje
Toledo
I was wondering if the redesigned center console that went in the libertys will fit in the 2002 liberty? They're fairly similar. Here's what I have now
Also, will the newer front grill and bumper work too? Not much difference either. I'm sure the turn signal connectors are different but could be worked to fit.
RenKJ
Canada
Man you're interior looks super clean and new, do you have any posts on detailing? Would also like led info for that lighting
teeje
Toledo
I definitely could make one. I've been detailing for years. Also do it as a side job in my garage [emoji5]
Just tell me what you'd like to see.
As for the LEDs, they are b8.4 LEDs and the climate control unit leds I believe are t4 neo wedge.
If you have an 02-04 and wanting a 05-07 front clip, then no everything is not easy to swap. Some have started but know of none that have went through the whole process. More different things then just a grill swap etc, its fenders/flares, structural supports then goes back to different even as far as the pinch weld area , PLUS the 02-04 looks better anyways
I suppose you could swap center console but the earlier ones work much better. Having 2 early and one later in the fleet I have the opportunity to drive each a lot and can't stand the later console
4x4kayak2112
tx
As tom said. The front clip needs new fenders, bumper, header panel, and grill.
Sent from my SM-N900P using Tapatalk
teeje
Toledo
Would you mind posting a picture of your center console?
