Clockspring
huntert98
Michigan
Well, Ive finished the rack and pinion replacment.
Got in, turned it in and air bag light turns on
I thought i was carful, I had the sear belt wrapped around through the wheel (centered) so it could only move a small amount each way
After the steering shaft was back in and connected I turned the wheel to full lock each way to get at my lower ball joint grease fittings. I noticed from center i had the normal amount of turning to the left, but the right seemed to turn about 3/8 to 1/2 a turn more than normal. Most likely this is the point at which i broke the spring
But If I get a new spring and put it in, what would prevent this from happening a second time? The steering coupling is all lined up with the rack (little notch for the bolt) So i dont think its a centering problem
Also, I might want a shop to replace the spring, would it be alright to drive ~5 to a shop? I understand the airbag may not deploy/horn wont work
Thanks
turblediesel
memberable
Alaska
Driving shouldn't be a problem. Mine made a crinkly plastic sound when I broke it.
Not very hard to change but you'll need a steering wheel puller. Air bag has a yellow wire connector if I remember right.
The factory service manual has an error regarding clockspring installation. Manual says to make one extra turn after blue shows up in little window... DON'T do the extra turn or the new one will break. Warn the shop if you don't do it yourself. Newer clocksprings might be pinned in the right location.
turblediesel
memberable
Alaska
I don't know about quality differences. My dog ate the steering wheel and I ate the clockspring. Replaced with a junkyard steering column and better dog.
Oh yeah... don't hammer on anything; steering column bearings are super sensitive.
Billwill
White River, South Africa
The new clock springs from Mopar come fully populated for air bags, cruise control, etc.
It comes with a white plastic locking pin....you remove this locking pin once you have fitted the assembly in place.
This is how I got a new part 4 years ago here in SA so your local dealers should have the same part!
Make sure you disconnect the battery first and clamp the loose positive lead to chassis for 20 minutes.
You need a two-claw puller to pull the steering wheel off...place a large nut on top of the spline shaft so the puller does not damage the thread inside the top of the shaft.;)
