Code P0402
Lib88888
Had this code throw up - with excessive flow detected. (This recently happened after checking my air filter, not realising the housing wasn’t properly tightened)
However fast forward, I re tightened the housing but the code now re appears even after having it cleared?
Unsure what to do next!
What year is your Jeep & is it a gasoline or diesel?
sunvale
michigan
Not sure what your needs are since you did not mention any.
However, I have some question re; the 06 CRD and the rear differential. Is the engine torque to much for the rear diff to experience a long life? I have some loud howling at 60-70 MPH. Replace all the wheel bearings etc but my suspicion is that the diff is from a gasser and Mercedes did not take into consideration that diesel is just to strong for it.
Any comments and or suggestions?
ikuo78
Japan
P0402
It might be the same as this.
EGR valve.
The diff is well capable of the diesels power output, however they are often forgotten when it comes to oil changes...
I don't think Mercedes had much input into the design of the engine or the diff, the 6 speed box was out of a sprinter van but otherwise its a US design with an Italian diesel engine.
