code p2181 engine is cold too long on 02 3.7
jeepguy4276
Fargo North Dakota
The temp gauge is in the center and the heat works fine. No cooling leak or low coolant. The thermostat was replaced about 1 1/2 years ago. Runs perfect. It's been sitting alot lately so I drove it yesterday and today to get some miles on it, otherwise it sat 2 weeks.
********sorry, code p1281
southernwake
All over
I agree with tjkj2002, start at the t-stat. And get an OEM one. I replaced mine with an aftermarket one over the Christmas holidays and put about 2000 miles on it without issue. While I was out of town for work my wife called me and told me the check engine light was on and I had her pull the code. Swapped out with an OEM one and haven't had any codes since.
Through my research these motors ( 3.7, 4.7) work best with OEM t-stat. I found several things where someone had an issue with that code and it was related to the non OEM t-stat and it was fixed by replacing with the OEM part.
Good luck,
Andrew
teeje
Toledo
Good luck,
Andrew
Me being one of them..in a brand new engine too
2002 Jeep Liberty 3.7L with brand new engine ;)
