summitjeep
- Joined
- Jul 17, 2021
- Messages
- 2
- Reaction score
- 0
Repair to previous owners wiring of trailer brake controller. I need a pic of the connector plug that goes to the brake pedal switch. 2 of the wires were shorted and burned in the dashboard wiring loom. Dashboard off and repairing a dark green with white stripe wire and a black ground wire. Luckily no other wires damaged in the dash harness. Attached picture of my plug to brake pedal switch with 2 wires missing.
This is a 2005 Jeep Liberty Diesel.
The wiring connector can be unplugged fairly easily but DO NOT remove the brake light switch from the pedal as it will not re-install when removed. New ones install only once.
Thank you for any help. The dash is not easy to remove and want to re-assemble as soon as possible.
